מצבר lifeYpo4 ללא מערכת ניהול?
The monolithic 12V batteries do not have any PCM (any electronics) inside. They consist of finely balanced cells with identical perfomace. The battery must be managed and operated as a single monolithic 12V block. We do not recommend operation in serial connection. For system with higher voltage 24/36/48V and more, we recommend to use Single cells 40Ah + BMS123Smart
Nominal voltage of the battery is 12 V and the operational voltage is 11,5 V - 15 V.
The maximum charging voltage for initial charge is 15 V.
Recommended subsequent charging is to 14,6 V.
The minimum voltage is 11 V.
Maximum discharge current is 3C continously for max 30 minutes from full charge.
Operating temperature -25°C up to 80°C (discharging)
These batteries are suitable for all traction applications including electric vehicles. Fully complies also for stationary applications - such as energy storage.
Also possible to use for starting internal combustion engines. In the Principles do not require any special electronics for use LP 12V batteries for starting, but it is very important to keep min. and max. voltage, so we recommend using any voltage indication unit, which you will be informed about the current Voltage. This is important especially for frequent starting. We recomend use some simple car Voltmeter. They consist of finely balanced cells with identical perfomace. The battery must be managed and operated as a single monolithic 12V block. We do not recommend operation in serial connection. For system with higher voltage 24/36/48V and more, we recommend to use Single cells 40Ah + BMS123Smart
https://shop.gwl.eu/LiFeYPO4-batteri...LP12V40AH.html
בלי קשר לנושא השרשור, לפי האתר שלה, היא נראית חברה רצינית ומעניינת, עם מוצרים רלוונטיים לתחום שלנו.
תגובה: מצבר lifeYpo4 ללא מערכת ניהול?
התחלת להיות גרשון? תעמל"ק לנו באמאשך.
איזה צחוקים...הגשש החיוור וורסיה 2020 :):)
