וזאת נחשבת לפאר הדמוקרטיה העולמית
מיל שקיבלתי מפורום 4X4 אמריקאי
אני מניח שעוד חברה קיבלו אותו
בארצות הברית התחילו להגביל את הנסיעה בשטח
לדעתי גם אנחנו בארץ במצב דומה
אז איפה יש חופש תנועה ?
בארץ ?
בארצות הברית ?
באירופה המערבית ?
או במזרח אירופה ?
U.S. Forest Service Land Use Restrictions Imminent
Did you know that our access to the entire United States Forest from coast to coast is in jeopardy?!?!?!
We are at DEFCON FIVE with the environmentalists and the U.S. Forest Service!
Now is the time to act!!!
I am very proud of the readers of Pirate4x4.com lately. Our Land Use forums have doubled in traffic over the past couple of months due to the outrageousness of what is going on out there. If you haven't been to our Land Use forums lately, I challenge you to take a look. I guarantee you will get pissed off! When I saw the Draft Plan the Forest Service put out for travel management on the Eldorado National Forest (where I happen to live, and where the world famous Rubicon Trail is) that was the last straw for me. I got pissed off and decided to do something about it.
And it isn't just the Eldorado National Forest. Travel management planning is going on in everyone's backyard whether it's Forest Service or BLM. Anti-access extremists are out in force pressing for closures everywhere. Tellico is threatened by an anti-access lawsuit. Moab access is threatened by overzealous BLM planning. Wilderness bills are rampant in Congress. Roadless area management is still being pushed in the courts. Even the little recreation that there is available in our Parks is still under attack. Check out the fight in Yellowstone.
It really is time to put up or shut up. I threw down the challenge last month to donate in the forums, and we were able to raise about $8,000 for BRC. While that is fantastic, I think we can do a lot better. Remember, without folks like the BLUERIBBON COALITION fighting for our rights to use public land, we might as well take up basket weaving. Join the Blue Ribbon Coalition and donate to the BRC Legal Fund. The beauty of BRC is they combine all the user groups into one big fist. I stuck $500 of my own money in the fight and you need to do what you can. If it's $20 or $5000, anything helps!!
While you are at it, get busy with your local club. Local involvement is where BRC does some of its best work. If you don't belong to a club, get off your butt and join one. You really CAN make a difference!
You can join BRC and donate to BRC Legal Fund online at a secure web location, set up just for Pirate4x4 at http://join.sharetrails.org . It only took me just a couple of minutes. If you aren't comfortable with that, then call them at 1-800-BlueRib. If you can't afford to do both, at least join BRC now and donate when you can afford it.
The members of Pirate4x4 can and will make a difference!
Lance Clifford
Pirate4x4.com
חוזר: וזאת נחשבת לפאר הדמוקרטיה העולמית
1 עירק
2 לבנון
3 עזה
4 טורה בורה
למעונינים לטייל באזורים אלו 0125566778899 לבקש את בן לאדן או אוסמה{חמד של בחור}
מומלץ בחום טיולים פצצה אש!
זה לא חדש.
האמריקאים והאירופאים מקפידים מאוד על העניין הזה. אתה לא יכול לנסוע מתי שאתה רוצה, איפה שאתה רוצה. שטחים נרחבים הם פרטיים ואין כניסה אליהם. יש מסלולים מוגדרים ופארקי 4X4 בתשלום, או שטחי בור, מחצבות נטושות וכו'. לעתים צריך לנסוע מאות קילומטרים כדי להגיע לפארקים כאלה ולשחק קצת בג'יפ.
עשינו בזמנו (2002) מבחן-דרכים בגרמניה למרצדס ML400CDI. (פעם, יבואן מרצדס לא נתן מכוניות למבחן בישראל. כדי לבחון מכוניות של מרצדס העיתון/מגזין שאתה כותב עבורו היה צריך להגיש בקשה מנומקת בכתב. אם היו מחליטים שאתה ילד טוב, היו שולחים אותך על חשבונם לגרמניה) יומיים שלמים הסתובבנו עם המפלצת המוצצת בין שטוטגארט לזלצבורג שבאוסטריה, וחיפשנו פיסת שטח כדי לנסוע קצת ולצלם. נאדה. גורנישט. הכל יפה ומדהים אבל פרטי, סגור, מגודר. מעט השבילים הפתוחים משולטים באופן שאינו משתמע לשתי פנים בתמרורים שאוסרים כניסת כל רכב ממונע אליהם. רוצה לטייל? לך ברגל, רכב על סוס או סע באופניים.
בהתחלה נהגנו ברוח המקום - היינו מנומסים, נסענו רק על כבישים ושמרנו על החוק. אבל לקראת סוף היום השני, כשהתברר שאין על מה לכתוב ואין תמונות מהשטח, הרהבנו עוז לצפצף על התמרור ולהיכנס לאחד משבילי היערות. הצלחנו לנסוע בכיף 10 דקות ולא יותר - אני לא אשכח את זוג הגרמנים הזקנים שרדפו אחרינו עם מקלות הליכה מתנופפים וצווחות זוועה בגרמנית, שבתרגום חופשי לעברית היו מביישות בוודאי את מיטב הקללות הגסות הפופולריות אצלנו.
בדמיוני ראיתי אותנו נופלים לידיהם של שני הזקנים האלה 60 שנה קודם לכן - כשאר הם בוודאי חבשו קסדה מרובעת עם צלב ברזל, נעלו מגפיים שחורים עד הברך, ואחזו בידם תת-מקלע שמייסר... כל מה שהיה חסר זה רק שידעו שלא רק שאנחנו משתינים בקשת על החוק שלהם, אלא שאנחנו גם יהודונים מישראל.
דרור סיכם יפה,
איציק,
אם תקרא את החוק המדובר
הם מציעים להגביל תנועה לשבילים מסומנים בלבד, זאת אומרת no trail blazing
אני אישית לא רואה את זה כבעיה גדולה,
ומדובר על יערות שמנוהלים ע"י USFS
אחוז קטן יחסית הכול האדמות הפתוחות (שבשליטה פדרלית)
האמת, שתמיד היה בעיה עם הירוקים.....הם תמיד לוחצים על הפדרלים לסגור עוד ועוד אדמות.
לפעמים זורקים להם עצם...
