יש מישהו שיכול לתת לי הסבר איך הנעילות ב-WJ עובדות?
ומדוע הן לא עובדות שתיהן ? קדימה וגם אחורה ?????
למרות שעשיתי החלפת שמנים ושמתי שמנים אוריגינליים !
אולי קישור כאתר של WJ לנושא
מישהו יודע עלות של משאבה כזאת ?
Quadra-DRIVE
On-demand 4WD system, utilizes a gerotor and coupling in the Quadra-Trac II transfer case and Vari-Lok front and rear axles for transferring torque from side to side
Sends torque to the rear wheels under normal driving conditions, able to send 100% of power to just one wheel when needed
Operates at maximum capability all the time
Includes a low-range mode for severe road conditions and low-speed pulling power
Includes a neutral mode that allows the vehicle to be towed
איך לבדוק אם המערכת תקינה.
DIAGNOSIS AND TESTING
(1) Park the vehicle on a level surface or raise
vehicle on hoist so that the vehicle is level.
(2) Remove the axle fill plug.
(3) Verify that the axle fluid level is correct. The
fluid level is correct if the fluid is level with the bottom
of the fill hole.
(4) Shift the transfer case into the 4WD full-time
position.
(5) Drive the vehicle in a tight circle for 2 minutes
at 5mph to fully prime the pump.
(6) Block the tires opposite the axle to be tested to
prevent the vehicle from moving.
(7) Shift the transfer case into the 4WD Low position
and the transmission into the Park position.
(8) Raise both the wheels of the axle to be tested
off of the ground.
(9) Rotate the left wheel by hand at a minimum of
one revolution per second while an assistant rotates
the right wheel in the opposite direction.
(10) The left wheel should spin freely at first and
then increase in resistance within 5 revolutions until
the wheels cannot be continuously rotated in opposite
directions.
(11) The Vari-lokt differential has engaged properly
if the wheels cannot be rotated in opposite directions
for a moment. After the wheels stop rotating for
a moment, the fluid pressure will drop in the differential
and the wheels begin to rotate once again.
(12) If the system does not operate properly,
replace the Vari-lokt differential.
http://www.wjjeeps.com/varilok.jpg
תודה לחברים שטרחו, וענו,והקדישו מזמנם !!!
עכשיו נשאר ללמוד את הנושא!
תבורכו !!!!!!
אודי כוכב הצפון
