לקראת החורף שמגיע, וחובת הדלקת אורות. ל GV 2006 (והלאה) יש אפשרות להדליק אורות "אוטמטית" עם פתיחת הסוויטץ.
http://newgrandvitara.net/modules/ne...#forumpost2833
DRL= daytime running lights
Turn ignition switch to ON position
Perform Steps a) through f) described below within 15
seconds after Step 1).
a) Turn lighting switch to CLEARANCE position.
b) Turn lighting switch to OFF position.
c) Repeat Steps a) and b) five times.
d) Turn lighting switch to HEAD position.
e) Turn lighting switch to OFF position.
f) Repeat Steps a) and e) five times.
After Step f), buzzer sounds twice which indicates
that DRL has been set to operable mode.
NOTE
When DRL setting has been changed from
operable mode to non-operable mode, buzzer
sounds once.
After confirming buzzer, turn ignition switch to OFF
position.
