המלצה על שמן מנוע ל - Td5
250.000 ק"מ , פעמיים אחרונות השתמשתי בשמן Morrise 5w40 סינטטי מלא .
לשמן יש תקן\סימון ACEA A3 / B3 / B4 במרכזי המליצו על סינטטי מלא A1 / B1 . אם הבנתי נכון הרי שהשמן שהשתמשתי בו הוא איכותי יותר מהנידרש.
אני מחפש המלצות לשמן מנוע ומקום לרכוש .
למטה יש את תכונות השמן שהשתמשתי בו עד כה
דניאל
Multilife 5W/40 Fully Synthetic
Multilife 5W/40 is a fully synthetic engine oil developed directly from motor racing technology and formulated for use in the latest passenger car and van engine designs. It has proved to be far superior to conventional oils and provides the following advantages:
1. Naturally high viscosity index, giving good flow rates to bearings at low temperatures, coupled with high film strength at high temperatures.
2. A natural low level of volatility, which prevents valuable oil constituents boiling off during periods of extreme temperatures inside the engine.
3. High film strength / lower fluid friction / lower wear.
4. Better thermal stability / improved internal cleanliness for engines.
Applications
Multilife 5W/40 has been designed to cope with the demands of the latest petrol and diesel engine designs, including turbocharged and supercharged units, requiring an oil of this viscosity and specification. Multilife 5W/40 is also qualified for use in Opel Carline and Powertrain Engines (diesel units covering a maximum of 50,000 kms during a 2 year period).
Multilife 5W/40 may be used against VW 501.01/505.01 standards but only for fixed service intervals. Also in engines tuned for racing, endurance events, rallying and other types of motor sport.
Performance Levels
API SM / CF
ACEA A3 / B3 / B4
BMW Longlife 01
MB 229.3
MB 229.5
Opel GM-LL-B-025 (Diesel)
Porsche Formal Approval
VW 505.01 (Pump Diesel)
Approved under VW Standard 502.00/505.00
