SCANER BY ELM327-ISO,CAN BUS
soft for this
OBD-II logger and OBD2CRAZY
for DISCO EDC-PIN8 go to PIN7-connector OBD2
for DISCO2-FULL OBD2
ABS,ENGINE,GEAR,BCU
FOR RANGE from 1994 to 2002
ENGINE,GEAR
DEFENDER-too DISCO
port in PC-COM1
VEHICLE 16 PIN CONNECTOR
INTERFACE SIGNAL CONNECTOR PIN
vehicle battery 16
Signal ground 4,5
L line (for ISO 9141) 15
K line (for ISO 9141) 7
תגובה להודעה: SCANER BY ELM327-ISO,CAN BUS
מה מיוחד בזה ?
ELM327 USB is the latest PC-based USB scan tool. It supports all OBD-II protocols and it works with a number of compatible programs. This ElmScan Interface allows you to connect your car to your PC/Laptop via USB and troubleshoot any problems in your vehicle by reading the Diagnostic Trouble Codes (DTC's) that appear when the "check engine" light is showing. Besides displaying DTC codes, it will allow you to scan live data right from your car's computer. Our ELM 327 interface works on the following protocols: * SAE J1850 - PWM * SAE J1850 - VPW * ISO 9141-2 * ISO 14230-4 - KWP 2000 * ISO 15765-4 / SAE J2480 - Controller Area Network (CAN)
לפחות תסביר מי נגד מי .
לקרוא קודי תקלה זה כבר לא סיפור .
SCAN TOOL-FUL OBD2,BUT ONLY ENGINE ,NOT FREEZ FRAME AND OTHER MODE
OBD2 LOGGER AND OBD2CRAZY-FULL MODE
FROM O1 TO 09+OBD2 EXTENDIT
ENGINE,GEAR,TRANSFER,BCU,ALARM AND OTHER
PORT COM1-USB
DRIVERS FOR ELM327
02 - J1850 Bus+
04 - Chassis Ground
05 - Signal Ground
06 - CAN High J-2284
07 - ISO 9141-2 K-Line
10 - J1850 Bus-
14 - CAN Low J-2284
15 - ISO 9141-2 L-Line
16 - Battery Power
CONNECTOR ELM327 HAVE PIN2,PIN4,PIN6,PIN7,PIN10,PIN14,PIN15,PI N16
SOFT ABSOLUTLY FREE
ELM327-SEE INTERNET
