למכירה סורק תקלות OBDII
חדש באריזה כולל דיסק למחשב, כבל USB למחשב, תיק נשיאה, פרוספקט.
מיועד לרוב סוגי הרכבים מ-1996 ומעלה.
מחיר 300 ש"ח.
טל' 0528-500760
MaxiScan MS509 OBD2 Scanner Code Reader Live Data
Prints data via your PC!
Reads live PCM Data Stream!
Vehicle Covered:
GM '96 - Current Year (OBD-II)
Ford '96 - Current Year (OBD-II)
Chrysler '96 - Current Year (OBD-II)
Toyota '96 - Current Year (OBD-II)
Honda '96 - Current Year (OBD-II)
NISSAN '96 - Current Year (OBD-II)
All other Asian and European '96 - Current Year (OBD-II)
Features & Benefits:
Works on all 1996 & later OBD2 compliant US, European & Asian vehicles.
Easily determines the cause of the “Check Engine Light”.
Retrieves generic (P0, P2, P3, & U0) & manufacturer specific (P1, P3, and U1) codes.
Turns off Check Engine Light, clears codes & resets monitors.
Displays DTC definitions onscreen.
Views freeze frame data.
Displays monitor & I/M readiness status (emissions).
Identifies pending codes.
Reads live PCM data stream.
Displays live O2 sensor test data.
Graphs data – (1996 and newer).
Reads, stores & playbacks live sensor data.
Memory/battery backup for off-vehicle data review & analysis.
Bilingual interface & definitions—English/Spanish.
Performs modules present test.
Retrieves vehicle information (VIN, CID and CVN).
Supports CAN (Controller Area Network) & all other current OBD2 protocols.
Built-in OBD2 DTC lookup library.
Large easy-to-read backlit LCD screen.
Software upgradeable via internet.
Prints data via PC.
http://desmond.imageshack.us/Himg18/...pg&res=landinghttp://desmond.imageshack.us/Himg850...pg&res=landing
