גרשון,
תקרא פה:DISCOVERY GEARBOX INTERLOCK ASSEMBLYאין גישה ויזואלית, לא הצלחתי למשש את הסלונואיד, אני חושב שזאת יכולה להיות הבעייה.
Discovery vehicles with automatic transmissions are equipped with a transfer gearbox interlock
solenoid which prevents the driver from moving the transfer gearbox lever from high to low or
from low to high unless the automatic transmission is in neutral. In any event, gear changes
should always be made at less than 5 mph (7 kph).
Shown below is the transfer gearbox interlock and related components used on Discoverys with
automatic transmissions through 2003 model year.
Beginning with the 2004 model year, the range select interlock solenoid is moved to the shift
lever housing.
תמונה
