Gauge |
| % Engine Load |
| Engine Coolant Temperature (ֲ÷F) |
| Engine Coolant Temperature (ֲ÷C) |
| Short Term Fuel Trim Bank 1 |
| Long Term Fuel Trim Bank 1 |
| Short Term Fuel Trim Bank 2 |
| Long Term Fuel Trim Bank 2 |
| Fuel Pressure (PSI) |
| Fuel Pressure (kPa) |
| Intake Manifold Absolute Pressure (MAP)(PSI) |
| Intake Manifold Absolute Pressure (MAP)(kPa) |
| RPM |
| MPH |
| KPH |
| Timing Advance |
| Intake Air Temperature (ֲ÷F) |
| Intake Air Temperature (ֲ÷C) |
| Mass Air Flow Sensor 1 (g/s) |
| Absolute Throttle Position 1 % |
| Bank 1 0xygen Sensor 1 Voltage*** |
| Bank 1 0xygen Sensor 2 Voltage*** |
| Bank 2 0xygen Sensor 1 Voltage*** |
| Bank 2 0xygen Sensor 2 Voltage*** |
| Run time since last start (hours:mins) |
| Miles traveled with Check Engine Light On. |
| Kilometers traveled with Check Engine Light On. |
| Fuel Pressure (Diesel & Direct Injection) (PSI) |
| Fuel Pressure (Diesel & Direct Injection) (10kPa) |
| Bank 1 Wide 0xygen Sensor 1 Lambda (voltage based)*** |
| Bank 1 Wide Oxygen Sensor 2 Lambda (voltage based)(UG Plus & UG MX only)*** |
| Bank 2 Wide 0xygen Sensor 1 Lambda (voltage based)*** |
| Bank 2 Wide Oxygen Sensor 2 Lambda (voltage based)(UG Plus & UG MX only)*** |
| Bank 1 Wide 0xygen Sensor 1 Lambda (current based)(UG Plus & UG MX only)*** |
| Bank 1 Wide Oxygen Sensor 2 Lambda (current based)(UG Plus & UG MX only)*** |
| Bank 2 Wide 0xygen Sensor 1 Lambda (current based)(UG Plus & UG MX only)*** |
| Bank 2 Wide Oxygen Sensor 2 Lambda (current based)(UG Plus & UG MX only)*** |
| EGR Flow % |
| EGR Flow % Error |
| Evaporative Purge % |
| Fuel Level % of full |
| Number of Warm-ups since Check Engine Light Cleared |
| Miles traveled since Check Engine Light Cleared |
| Kilometers traveled since Check Engine Light Cleared |
| Evaporative System (PSI) |
| Evaporative System (Pa) |
| Barometric Pressure – Inches of Mercury (inHg) |
| Barometric Pressure – Inches of Mercury (kPa) |
| Catalytic Converter Bank 1 Sensor 1 Temperature (ֲ÷F) |
| Catalytic Converter Bank 1 Sensor 1 Temperature (ֲ÷C) |
| Catalytic Converter Bank 2 Sensor 1 Temperature (ֲ÷F) |
| Catalytic Converter Bank 2 Sensor 1 Temperature (ֲ÷C) |
| Catalytic Converter Bank 1 Sensor 2 Temperature (ֲ÷F) |
| Catalytic Converter Bank 1 Sensor 2 Temperature (ֲ÷C) |
| Catalytic Converter Bank 2 Sensor 2 Temperature (ֲ÷F) |
| Catalytic Converter Bank 2 Sensor 2 Temperature (ֲ÷C) |
| Battery Voltage (Measured by ECM) |
| UltraGauge Battery Voltage (Measured by UG) |
| Load absolute % |
| AFR Commanded Ratio |
| Relative Throttle Position % |
| Outside Ambient Air Temperature (ֲ÷F) |
| Outside Ambient Air Temperature (ֲ÷C) |
| Absolute Throttle Position 2 % |
| Accelerator Pedal Position 1 % |
| Accelerator Pedal Position 2 % |
| Command Throttle Position % |
| Boost Pressure, (Relative Pressure) (PSI) |
| Boost Pressure, (Relative Pressure) (kPa) |
| Brake Horsepower 1 |
| Brake Kilowatts 1 |
| Torque 1 (ft lbs) |
| Torque 1 (N.m) |
| Brake Horsepower 2 |
| Brake Kilowatts 2 |
| Torque 2 (ft lbs) |
| Torque 2 (N.m) |
| Mass Air Flow Sensor 2 (g/s)– Calculated |
| Instantaneous MPG |
| Instantaneous KPL |
| Instantaneous L/100Km |
| Average MPG – General |
| Average KPL – General |
| Average L/100Km – General |
| Average MPH – General |
| Average KPH – General |
| Run Time – General |
| Miles – General (miles) |
| Kilometers – General (miles) |
| Fuel Used – General (gallons) |
| Fuel Used – General (liters) |
| Average Gallons/Hour - General |
| Average Liters/Hour - General |
| Fuel Level (gallons) |
| Fuel Level (liters) |
| Instantaneous Gallons/hour |
| Instantaneous Liters/hour |
| Distance to Empty (miles) |
| Distance to Empty (kilometers) |
| Time to Empty |
| Volumetric Efficiency (MAP vehicles only) |
General Trip Gauges |
| Average MPG |
| Fuel Used |
| Average Gallons/hour |
| Average MPH |
| Distance (miles) |
| Run Time |
| Average KPH |
| Average KPL |
| Average L/100Km |
| Liters Used |
| Average Liters/Hour |
| Distance (kilometers) |
Short Trip Gauges** |
| Average MPG |
| Fuel Used |
| Average MPH |
| Distance (miles) |
| Run Time |
| Average KPH |
| Average KPL |
| Average L/100Km |
| Liters Used |
