תגובה: תחליף לWD הכנה ביתית
לא ראיתי את הפרסום המדובר, אבל חיפוש קצרצר ל- HOME MADE WD40 העלה את זה:
https://www.engineeringforchange.org...ating_oil.html
90% שמן בישול עם 10% אצטון
איל
איזה שמן בישול ? יש לי רק שמן זית בכבישה קרה.
מה עם נוזל בלם? או איזה 6040 ה?
תגובות צוננות ממי שכבר ניסה :
BackDoorMan
הבעיה שאצטון ו ATF לא מתערבבים, קשה ליצר מהם אמולסיה יציבה והאצטון מתנדף במהירות.
עובד בתנאים המתישים את המשתמש.
How stupid of you to repeat this BS. If you had tried it you would know that acetone and ATF do not mix anymore than oil and water. You should put some of each in a container and hope you live until they mix."
| -2011, 09:30 AM |
http://bbs.homeshopmachinist.net/images/icons/icon1.gif
Yep, they don't mix, you have to shake it up really well first. I think that was stated in the article, or in a followup to it. It mixes sort of like the salad dressing.
I've used this. It worked for me using ATF, easily at least as well as kroil, PB, or liquid wrench, subjectively better in my estimation.
The guy who wrote the original article, did some actual tests by making several steel test samples with a tight fitting pin in a hole. He rusted them with (I think) a salt spray, then applied the various mixtures to them and allowed them to sit. He then pressed the pins out with a press that could measure the force applied. Not 100% rigorously scientific really, but way better than anything else I've read on the topic.
It is in the April-May 2007 Machinist Workshop.
#15
http://bbs.homeshopmachinist.net/ima...n/post_old.gif 03-27-2011, 10:40 AM |
I tried this, and it seemed to work pretty well, though I didn't approach it scientifically. It does require shaking. My problem was that the acetone evaporated so fast that it wasn't worth mixing much at a time. If you do make up some, you'll need to keep it in a bottle and decant it into the oil can when you need it.
I find that most of the time it's not worth the bother, and get the job done with something less volatile. |
כן, ראיתי אותם... אבל שני המוצרים בבית. סטייבלייזר לינק שמסרב להיפרד מהמוט גם לאחר ריסוס של WD, מה יש לי להפסיד?
שחכתי להודות לחברים שמצאו את הקישור, תודה!
אם כבר דיברו על קולה זה אכן עובד
סיפור קצר
חבר קנה גימני היתה לו בעיה בוואקום של הלוקרים אחד הצינורות הברזל היו סתומים זה צינור מפותל
מה שלא ניסנו לחץ אויר.. ספריי WD40... חותר... וכו'.. כלום לא עזר
אחרי חצי שעה בערך של ניסויים
לקחנו טיפה קולה במזרק והכנסנו לתוך הצינור עם הלחץ של המזרק
והופפפפ אחרי 5-10 דקות השתחררה הסתימה
כמובן שהכל היה סתום בחלודה
