מציג תוצאות 1 עד 13 מתוך 13
נושא: DEFENDER PUMA
    חבר רשום Gershon's Avatar
    תאריך הצטרפות
    מיקום
    Tel Aviv, Israel, Israel
    הודעות
    3,976
    ברירת מחדל DEFENDER PUMA
    ENGINE-104kwt
    pic
    tel:054-7367258
    תאריך הצטרפות
    מיקום
    הודעות
    3,976
    ברירת מחדל תגובה: DEFENDER PUMA
    body
ID:	43097   Click image for larger version.
    tel:054-7367258
    תאריך הצטרפות
    מיקום
    הודעות
    3,976
    Item Part Number Description
    1 - Radiator top hose
    2 - Cooling fan top cowl
    3 - Expansion tank
    4 - Passenger compartment heater connections
    5 - Exhaust Gas Recirculation (EGR) cooler
    6 - EGR cooler outlet hose
    7 - Expansion tank hose
    8 - Fuel cooler
    9 - Engine oil cooler
    10 - Coolant pump
    11 - Fuel cooler feed and return hoses 448 of 1212
    tel:054-7367258
    תאריך הצטרפות
    מיקום
    הודעות
    3,976
    A - Exhaust manifold connection
    B - Intake air connection
    C - Charge air cooler connection
    D - Exhaust pipe connection
    1 - Turbine housing
    2 - Oil feed
    3 - Actuator motor
    4 - Actuator lever
    5 - Oil return
    OVERVIEW
    The variable vane turbocharger, fitted to the exhaust manifold, makes it possible to vary the exhaust gas flow of the
    turbine, dependent on engine operation. This improves the power transfer to the turbine wheel and compressor,
    particularly at low engine speeds, thus increasing the boost pressure. The guide vanes are opened progressively as the
    engine speed increases so that the power transfer always remains in balance with the required charger speed and the
    required boost pressure level. Variable vanes facilitate better use of the exhaust gas energy so as to further improve
    the efficiency of the turbocharger and thus of the engine, compared to the more conventional 'wastegate control'.
    Advantages:
    High torque at both high and low engine speeds
    Continuous and optimum adjustment for all engine speeds
    No wastegate valve required, exhaust energy is better utilised, less back-pressure in conjunction with same
    compressor work
    Low thermal and mechanical load improves engine power output
    Lower emissions
    Optimised fuel consumption over the entire engine speed range
    A Direct Current (DC) rotary actuator motor operates a drive shaft. The drive shaft is connected to the vanes by an
    actuating lever. Adjustment of the vanes is achieved by moving the actuating lever. When the drive shaft is turned, a
    signal is created at the end of the drive shaft; this feedback signal is used to determine the angular position of the
    vanes. This information is transmitted to the Engine Control Module (ECM).
    The turbocharger is designed for fail safe operation. If a fault occurs regarding the control of the unit, the vanes default
    to the fully open position so as to produce minimum boost. The ECM detects any malfunctions in the stepper motor and
    generates Diagnostic Trouble Codes (DTC).
    PRINCIPLES OF OPERATION
    Item
    A - Low Engine Speed
    At low engine speeds the volume of exhaust gas is low so the vanes are moved towards the closed position to reduce
    the turbine inlet area. This reduction causes an increase in the gas velocity into the turbine wheel thereby increasing
    wheel speed and boost.
    B - Moderate Engine Speed
    As the engine speed increases and the volume of exhaust gas increases the vanes are moved towards the open position
    to increase the turbine inlet area and maintain the gas velocity.
    C - Maximum Engine Speed
    At maximum engine speed the vanes are almost fully open maintaining the gas velocity into the turbine wheel.
    Barometric Pressure Sensor
    When the vehicle is driven at high altitudes the ambient pressure reduces causing the compressor wheel to do less work
    for the same boost pressure. To prevent the turbine wheel from over-speeding under these conditions a barometric
    pressure sensor, located in the ECM, protects the turbocharger by opening the vanes further to reduce the turbine wheel
    speed. This is known as the altitude margin of the turbocharger.
    Turbocharger Lubrication
    The rapid acceleration and deceleration response demands of the turbocharger rely greatly on a steady flow of clean oil.
    The oil supplied from the engine's lubrication system provides lubrication to the turbocharger's spindle and bearings,
    while also acting as a coolant for the turbocharger centre housing.
    To maintain the life expectancy of the turbocharger, it is essential that the oil has a free-flow through the turbocharger
    and unrestricted return to the engines sump. It is therefore imperative that the engine oil is replenished at regular
    service intervals with the recommended quality and quantity of oil.
    Charge Air Cooler
    The charge air cooler is used to increase the density of air as it flows from the turbocharger compressor to the intake
    manifold.
    Compression of the charge air by the turbocharger raises the temperature of the air. This generation of heat expands
    the air density and consequently less oxygen is able to enter the cylinders, reducing the engines power. To overcome
    this, the air is routed through the charge air cooler before it enters the engine; the temperature is reduced by
    transferring the heat to atmosphere.
    from MANUAL LANDROVER
ID:	43105   Click image for larger version.
    tel:054-7367258
    תאריך הצטרפות
    מיקום
    הודעות
    3,976
    1 - Vacuum pump
    2 - Coolant pump
    The coolant pump is installed at the front, LH side of the cylinder block and is secured with 4 bolts. The coolant pump is
    driven by the accessory drive belt via the crankshaft. The engine thermostat is located in the rear of the coolant pump
    housing and begins to open at 88°C (190°F).
    For additional information, refer to: Engine Cooling (303-03 Engine Cooling - 2.4L Duratorq-TDCi HPCR (103kW/140PS) -
    Puma, Description and Operation).
    The vacuum pump is mounted on top of the cooling pump and is secured with 3 bolts. The vacuum pump is also driven
    tel:054-7367258
    תאריך הצטרפות
    מיקום
    הודעות
    3,976
    1 - Power steering pump
    The power steering pump is located at the front, LH side of the cylinder block, directly below the coolant pump. The
    power steering pump is attached to a mounting bracket via 3 bolts and the mounting bracket locates on the cylinder
    block and ladder frame via 4 bolts.
    For additional information, refer to: Power Steering (211-02 Power Steering, Description and Operation
    The high-pressure fuel pump is located under the intake manifold, behind the coolant and vacuum pump assembly. The
    fuel pump is driven by the timing chain at the front of the engine and includes a transfer pump and a high pressure
    pump which are serviced as one unit.
    The pump provides the interface between the low and high-pressure systems. Its function is to always provide sufficient
    compressed fuel under all operating conditions and for the entire service life of the vehicle.
    The transfer pump draws the fuel from the fuel tank, through the fuel filter, and then pumps the fuel to the highpressure
    pump. The transfer pump maintains a constant fuel pressure through a regulating valve within the fuel pump;
    this is known as transfer pressure.
    The high-pressure pump receives fuel at transfer pressure from the transfer pump and increases the fuel pressure. The
    high pressure fuel is then transferred from the high-pressure pump to the common rail.
    For additional information, refer to: Fuel Charging and Controls (303-04A Fuel Charging and Controls - 2.4L Duratorq-
    TDCi HPCR (103kW/140PS) - Puma, Description and Operation
ID:	43108   Click image for larger version.
    tel:054-7367258
    תאריך הצטרפות
    מיקום
    הודעות
    3,976
    1 - Exhaust camshaft sprocket
    2 - Inlet camshaft sprocket
    3 - Primary drive chain
    4 - Primary drive chain guide
    5 - High-pressure fuel injection pump sprocket
    6 - Bolt (4 off)
    7 - Primary drive chain guide
    8 - Bolt (2 off)
    9 - Crankshaft sprocket
    10 - Secondary drive chain
    11 - Bolt (2 off)
    12 - Automatic tensioner
    13 - Primary drive chain tensioner arm
    14 - Bolt (4 off)
    15 - Primary drive chain guide
    A multiple link primary drive chain transmits the drive from the sprocket on the crankshaft to the exhaust camshaft, the
    inlet camshaft and the high-pressure fuel pump. The secondary drive chain transmits drive from the sprocket on the
    crankshaft to the oil pump located on the underside 3 0of9 th eo lafd d1e2r f1ram2e.
    tel:054-7367258
    אמנם החזקתי בלנדרובר כמס' חדשים , אפילו ביקרתי אצל גרשון במס' הזדמנויות , עדיין אני מתקשה להבין את פשר ההודעות האלו שהוא מעלה -
    האם מישהו ממשתתפי הפורום יכול להאיר את עיניי בבקשה ? האם מדובר בשפת סתרים כלשהי שרק בעלי לנדרובר מבינים ?
    חבר רשום Tourist's Avatar
    תאריך הצטרפות
    Nov 2010
    מיקום
    עתלית, חוף הכרמל
    הודעות
    1,853
    הוא מתכוון ש- jhsfgscbksjdbfvkbbwesurjhvcbswjeuhfbnvce wikruj וגם אולי ksjrvhevfjefb
    אבל יש לו טעות רצינית אם הוא חושב ש-jhergfevjbeijvbleijv מתאים ל-kjhdvbkjvb !!!!!!!!!!!!
    תאריך הצטרפות
    מיקום
    הודעות
    3,976
    אנשים רוצים לדעת איך בנוי DEFENDER PUMA
    I have full info about this car from UK
    tel:054-7367258
    מה זה דיפנדר פומה ? מי אותם אנשים שרוצים לדעת איך הוא בנוי ? למה העתקת עמודים מספר היצרן של הרכב לתוך שרשור בפורום מועילה למישהו ?
    תעזרו לי כאן הא? לא רוצה למחוק הודעות שאולי מסייעות כאן למישהו באופן נשגב מבינתי ...
    תאריך הצטרפות
    מיקום
    הודעות
    3,976
    DEFENDER PUMA-NEW DEFENDER
    engine 2400-td4-common rail
    tel:054-7367258
    תאריך הצטרפות
    מיקום
    הודעות
    3,976
    כדי ניסיון להחליף את המזרקים יכול לתת 2
    for DEFENDER PUMA 2.4
    tel:054-7367258
נושאים דומים
  1. DEFENDER 2012?
    על ידי Gershon בפורום פורום לנדרובר Land Rover
    תגובות: 4
    עדכון אחרון: 13-05-11, 22:20
  2. קניית Defender 110 HD חדש
    על ידי itayt בפורום פורום לנדרובר Land Rover
    תגובות: 21
    עדכון אחרון: 16-11-10, 06:29
  3. new DEFENDER
    תגובות: 0
    עדכון אחרון: 03-08-10, 11:32
  4. DEFENDER 100
    תגובות: 5
    עדכון אחרון: 21-05-09, 21:04
  5. Defender 90 Here i come.
    על ידי 6opka בפורום פורום ג'יפאים מתחילים + יעוץ לפני קנייה
    תגובות: 7
    עדכון אחרון: 09-05-08, 16:34
הרשאות פרסום
  • אין באפשרותך לפרסם תגובות
  • אין באפשרותך לצרף קבצים
