מציג תוצאות 1 עד 2 מתוך 2
נושא: yaesy ft-1900r
    ברירת מחדל yaesy ft-1900r
    ULTRA RUGGED 55-WATT 144 MHz MOBILEThe FT-1900R is a ruggedly-built, high-performance 55-Watt 144 MHz mobile FM transceiver with outstanding receiver performance and crisp, clean audio. Optimized for ease of operation day or night, the FT-1900R is one tough radio for operating in a tough world!
    55 Watts of Power OutputThe FT-1900R provides a hefty 55 Watts of power otput, with "low power" settings of 25, 10, and 5 Watts, for situations where full power is not required.Large LCD DisplayThe large 6 digit backlit LCD on the FT-1900R ensure ecellent visibilityLoud Audio with Internal SpeakerThe FT-1900R packs 3W BIG watts of Loud Audo with its own Internal Speaker for those noisy environments.Extended Receiver CoverageThe FT-1900R provides receiver coverage of 136-174 MHz, so you can listen in on a wide variety of commercial, military, public safety, and marine communications.Illuminated Microphone with Keyboard Frequency EntryThe supplied MH-48a6j DTMF Microphone is illuminated for eas of nighttime use, and you may enter operating frequencies directly from the keypad. What's more, memory channels may also be recalled directly via the keypad.200 Memory channels with Alpha-numeric LabelingThe FT-1900's extensive memory system includes 200 regular memories, ten pairs of band-limit memories, 8 memory banks,and a one-touch "Home" channel. Memory channels store repeater offset information, as well as CTCSS or DCS data, and can have a six-character label appended, for quick channel recognition. And the memories may be allocated into as many as eight memory banks, for more efficient scanning.Dedicated 10-channel NOAA Weather Broadcast Channel Bank (U.S. version)Included in the FT-1900r is a dedicated, quick-access memory bank that contains the ten standard NOAA Weather Information Channels, so you can keep track of weather conditions expected for your area.ProgrammableFour user-programmable "soft" keys are provided on the MH-48a6j microphone, allowing you to bring often-used Menu items, or front panel key functions, to your fingertips.Built-in CTCSS and DCS Encoder/Decoder CircuitsThe FT-1900R includes both CTCSS and DCS Encoder/Decoder circuitry, with Reverse CTCSS Decoding also available, to mute your receiver when a particular tone is received (instead of opening your squelch). And you canencodeCTCSS and decode DCS, or vice versa, too, if your application requires
    1200
    שקלים 0544653240
    ברירת מחדל תגובה: yaesy ft-1900r
    [QUOTE=bumer;497031]
    1200
    שקלים 0544653240
הרשאות פרסום
  • אין באפשרותך לפרסם תגובות
  • אין באפשרותך לצרף קבצים
