тоег 2 оъек 2 шащепшащеп 12
оцйв ъецаеъ 21 тг 27 оъек 27
  1. #21
    бшйшъ озгм ъвебд мдегтд: айк йегтйн айжд чеофшсеш оъайн - йщ домцеъ ??
    дйй ,
    24$ лемм ощмез жд тбеш дчеофшсеш щоефйт баъш щм ebay , мщн дбдшд жд ма аеъе дчеофшсеш щм Eshetach еощен ддбгм дйд отрййп мгтъ од дщерй бйп долщйшйн.
    трййп аеъй мгтъ одн дръерйн щцшйк мгтъ щбайн мчреъ чеофшсеш лжд :
    лод PSI цшйк мдйеъ дчеофшсеш бйзс мсев дцойв щшецйн мрфз еле' .
    арй вн оъшщн щдчеофшсеш щм Eshetach лршад оъайн еййщшег осфйч жоп .....
    ъегд
    шоеп
  2. #22
    збш шщен oren61's Avatar
    Jul 2009
    бъ-щмод
    вн арй тн ишефш чрйъй аъ дчеофшсеш отйгп , оома одш мма щен бтйд ейеъш ошлб азг лм фтн.
    бчйцеш оеомх.
  3. #23
    збш шщен BackDoorMan's Avatar
    Sep 2006
    земеп
    д WARN деа офмцъ йчшд , бщмйщ озйш йщ аефцйд иебд , ан лй щмйщ о 1000 жд тгййп ма оти.
    деа рбзш лиеб бйеъш обйп 15 чеофшсешйн бобзп щртшк еролш вн http://store.arbusa.com/ARB-On-Board...P12-P3573.aspx , дййцеш баесишмйд.
    Made in Australia. Hard case provides great protection.
    50 percent claimed duty cycle - 30-minutes on / 30-minutes off. 105 pound pressure cut off switch, which also allows unit to be left on when air line is removed from tyre. 40 amp inline fuse. ON/Off switch in case. Lid is designed to switch compressor off when closed - great safety feature. High quality heat resistant air line is easy to unravel. Large diameter sintered bronze air cleaner rated for fine bull dust is unique. Very fast to inflate tyres given the small physical build. One of the few compressors that is not a 'copy' of another unit. Test ended at 95psi due to pressure cut of switch activating.
    Pumping the tire to 45 psi took three minutes, probably because of back pressure as the tire pressure increased. Try that with the bargain-barn compressor…
    The CKMP12 compressor has the highest-rated flow for a portable air compressor in its class. It is constructed of light weight, high strength engineering-grade materials including military and space age components. The unit is fully sealed against moisture and dust. The motor is 100% ball-bearing equipped, has a unique linear brush pre-load system for long life, low heat, and is fairly quiet in operation. If used too long and it begins to overheat, a thermal cut-off switch will switch it off before any damage occurs.
    The illuminated isolating switch is great for night use and warns and protects the user from accidental sparks when attaching the alligator clips to the battery. The heavy duty Maxi-fuse leads have professional
    in-line circuit protection.
    The unit motor has a hard-anodized bore and Teflon impregnated carbon fibre piston seal for reduced friction and a trouble free life. The compressor piston is fitted with a German made high shock rated cylindrical roller bearing, while a high density and high flow washable sintered bronze filter element ensures air quality. The unit is also equipped with an over-pressure safety valve as
    back-up protection against pressure switch failure, thermal over pressure generated in a hot vehicle, or the accidental connection to an external high pressure source.
  4. #24
    цйиеи рлъб бочеш тм йгй ramon цфйд бдегтд
    дйй ,
    доелш одмйрч щцйшфъ, блмм ма щемз машх, елод щлбш аошъй, озйш щм чеофшсеш + - щеед тшк мжд щтйгп оелш, йдйд отм 300 щ"з. обзйръй жд ма щеед лй бозйш лжд зщеб щйдйд ме "аба".
    дрд огзсйн оайбйй мфй озйш + ощмез машх:
    http://shop.ebay.com/i.html?_trkparm...3&gbr=1&_pgn=3
  5. #25
    цйиеи рлъб бочеш тм йгй s_n_p цфйд бдегтд
    дйй ,
    ъегд млемн , дчеофшсеш (иеб ре етег лод гбшйн) ршлщ бщтд иебд, арй дмлъй бсеу тм дчеофшсеш щм тйгп. ослйн щтгйу щйдйд ме "аба" .
    мвбйй ebay рлеп , абм ан ъбгеч аъ аеъе дсев олод сфчйн ъшад щан аъд оъоегг тмйе болшж лзмч одърайн дощмез бзйрн , арй лбш двтъй моцб ъщмен абм озчъй блгйй мчреъ аъ жд лап еолап.
    щрд иебд
    шоеп
  6. #26
    збш шщен йеръпоцфд's Avatar
    Aug 2006
    точ йжштам
    цйиеи рлъб бочеш тм йгй idanw цфйд бдегтд
    абм ъре мй лод йойн, арй абщм ощде
    ре тйгп, йщ згщ?
    (озлйн бсбмреъ)
  7. #27
    збш шщен idanw's Avatar
    гшен
  1. зв щоз - обчщ домцд мчеофшсеш оъайн мв'йф
    тм йгй Y-S бфешен фешен шлб щиз 4X4 лммй
    тглеп азшеп: 19-09-09, 20:25
  2. озфщ чеофшсеш мшлб - домцеъ?
    тм йгй yscheiner бфешен фешен шлб щиз 4X4 лммй
    ъвебеъ: 20
    тглеп азшеп: 26-10-08, 13:22
  3. дан чеофшсеш чип оъайн моеск бйъй
    тм йгй оайш шеибшв бфешен фешен шлб щиз 4X4 лммй
    ъвебеъ: 12
    тглеп азшеп: 11-01-08, 16:05
  4. айжд чеофшсеш арй цшйк???
    тм йгй аййм бфешен аеу-иефйч
    тглеп азшеп: 05-01-04, 20:00
