ξφιβ ϊεφΰεϊ 1 ςγ 3 ξϊεκ 3
    ηαψ ψωεν tzagi's Avatar
    Jul 2005
    Granada Hills CA
    αψιψϊ ξηγμ αψαιχιε θχρπι ειψθεΰμι
    μδπΰϊλν....εϊεγδ μςεξψ ςμ δϊψβεν.
    Unlike popular belief, real Texans don't use bbq sauce!....ever!
    απιβεγ μΰξεπδ δψεεηϊ, θχρπι ΰξιϊι μΰ ιωϊξω αψεθα αψαιχιε, αηιιν
    That's for the stupid northerners.
    δτψιαιμβιδ δζΰϊ ωξεψδ μξθεξθξιν ξδφτεο.
    What is used on the meat is a mix of spices called "bbq seasoning", or rub
    ξδ ωλο ωξιν ςμ δαωψ διΰ ϊςψεαϊ ωμ ϊαμιπιν ωπχψΰϊ, ϊαμιο μαψαιχιε, ΰε ςιρει.
    you can mix your own, or just buy it at the store (nor relevant to you)
    ΰτωψ μδλιο ΰϊ δϊςψεαϊ μαγ ααιϊ, ΰε τωεθ μχπεϊ ξελο ξδηπεϊ (ξδηπεϊ τδ, μΰ αιωψΰμ)
    and there is pineapple juice, and that is generally mixed with cherry juice for moisture control.(anti drying)
    ειω ΰϊ δξιυ ΰππρ, ΰεϊε ξςψααιν ςν ξιυ γεαγαπιν ςμ ξπϊ μωξεψ ςμ μηεϊ ξρειιξϊ αϊεκ δξςωπϊ
    A real Texas BBQ is done on a smoker, not a grill or a MANGAL
    αψαιχιε θχρπι ΰξιϊι πςωδ αξςωπϊ, μΰ ςμ βψιμ εμΰ ςμ ξπβμ.
    A smoker is a cooking device that uses indirect heat, and very little of it, most of the cooking is done by smoke, at low temperature (less then 100c)
    δξςωπϊ διΰ ξλωιψ αιωεμ ωξωϊξω αξχεψ ηεν μΰ ιωιψ εξςθ ξΰγ ηεν, δαιωεμ πςωδ ς"ι δςωο αθξτψθεψδ πξελδ ξΰγ.
    There is a main cooking area, like a MANGAL, but the heat doesn't come from underneath, it comes from the fire box on the side,
    ιω ΰιζεψ αιωεμ ψΰωι ωπψΰδ λξε ξπβμ, ΰαμ μμΰ ξχεψ ηεν ξϊηϊιε (βημιν) δηεν ξβις ξχετρΰ χθπδ μφγ δΰιζεψ δζδ αϊελδ ιω ΰϊ δςυ..
    once the wood in the fire box is "on fire", the door is closed and the oxygen supply is cut off, the fire dies(and so is the heat) and
    smoke is produced, it travels thru a cavity to the cooking area and exits thru the vents ...or a chimney.
    αψβς ωδςυ πξφΰ αϊεκ δχετρΰ δζΰϊ πιγμχ, ρεβψιν ΰϊ δγμϊ μξπες λπιρδ ωμ ηξφο εηεπχιν ΰϊ δΰω, δΰω λαιϊ, δηεν πιωΰψ εδςωο πεφψ δςωο ςεαψ αϊςμδ μΰιζεψ δαιωεμ δψΰωι ειεφΰ ξξπδ γψκ τϊηι ΰιεεψεψ, ΰε ΰψεαδ..
    Generally speaking the cooking time is 2 hours a kg, per piece and not per load, however there is no such thing as overcooking, the longer it smokes the better it gets. Cooking time can also depend on outside temprature and direct exposure to the sun (not a good thing usualy)
    αΰετο λμμι δηεχ ΰφας ΰεξψ ωϊι ωςεϊ ςιωεο μλμ χ"β ωμ αωψ (ζδ ξϊιιηρ μηϊιλδ δβγεμδ αιεϊψ, ΰν ιω μκ ηϊιλδ ωμ 3 χ"β εηϊιλδ ωμ χ"β δςιωεο ιςωδ μξωκ 6 ωςεϊ εμΰ μξωκ 8), αλμ ξιχψδ μΰ χιιν δξεωβ "ωψεσ" ΰε ξαεωμ ιϊψ ςμ δξιγδ, λλμ ωδαωψ ιδιδ "ξςεωο" ιεϊψ, δεΰ ιδιδ θεα ιεϊψ.
    ζξο δαιωεμ ϊμει βν αθξτψθεψδ δηιφεπιϊ εδηωιτδ διωιψδ ωμ δξςωπϊ μωξω (μΰ γαψ ψφει μλωςφξε).
    What wood to use?
    αΰιζδ ςυ ξωϊξωιν?
    The wood used is very important for good results, around here Mesquite is popular, its a locally grown tree with very deep red color, and gives excellent flavor, however apple and pecan are also very popular, each gives a different flavor,there is room for experimentation here.
    δςυ δεΰ πεωΰ ηωεα, ςυ θεα ιαιΰ ΰιϊε θςν περσ μαωψ, αθχρρ ξωϊξωιν μψεα αξρχιθ, βγμ αΰζεψ, αςμ φας ΰγεν ςξεχ επεϊο θςν ξφειιο, απερσ, ιω ςφι ϊτεη ετχΰο, λμ ΰηγ ξΰμδ λξεαο πεϊο θςν ωεπδ, χη ωιω ξχεν μ"πιριεπεϊ" εϊψεφιν μςιωεο αωψ.
    what are the traditional side orders?
    ξδ απεβς μξπεϊ περτεϊ?
    To keep it simple: baked potato, baked or ranch beans, corn on the cob
    αχφψδ εατωθεϊ, ϊτεηι ΰγξδ, ΰτειιν. ωςεςιϊ, ΰτειιδ ΰε ξαεωμϊ εχμηι ϊιψρ.
    What kind of wine goes well with it?
    ΰιζδ ιιο δεμκ θεα ςν δαωψ?
    Defiantly red, and flavorful to compliment the meat, cabernet sauvignon is a winner
    ΰγεν πχεγδ. ψφει ΰιλεϊι, μΰ γψΰςχ α10 ωχμ ξδξλεμϊ ωμ δβψεζιπι ατιπδ.λζδ ωιζψεν θεα ςν δαωψ, χαψπδ ρεαιπιεο δεΰ αηιψδ θεαδ.
    What about Beer?
    ξδ απεβς μαιψδ?
    Yah...lots of it.
    ϊξιγ, ελξδ ωιεϊψ.
ID:	4525   Click image for larger version.
ID:	4526   Click image for larger version.
ID:	4527   Click image for larger version.
    Jul 2005
    Granada Hills CA
    αψιψϊ ξηγμ ηεζψ: αψαιχιε θχρπι ειψθεΰμι
    εαδξωκ.......
    What kind of meat can be smoked?
    ΰιζδ αωψ λγΰι μωο?
    ANY kind of meat can be smoked with incredible results.
    λμ ρεβ εδϊεφΰεϊ ιδιε ξγδιξεϊ
    however poultry(chicken or turkeys) have to be marinated overnight in a salt brine(water, sea salt, spices), mostly to prevent dryness as the cooking time is longer then beef or pork
    αλμ ΰετο, ςετεϊ (τψβιϊ, δεγε) φψικ μδωψεϊ αξψιπγδ ωμ ξι ξμη εϊαμιπιν μξωκ δμιμδ αςιχψ μξπες δϊιαωεϊ ωμ δαωψ διεϊ εζξο δςιωεο ωμδν ΰψεκ ιεϊψ ξαχψ ΰε ηζιψ.
    fish is another good candidate.
    βν γβ ιλεμ μλϊ ξφειιο αξςωπϊ.
    The most popular cuts to be smoked are brisket, roasts, loins, and ribs, almost anything that is usually cooked in an oven and not on the grill, it turns cheap cuts of meat into a culinary masterpiece...everytime.
    δπϊηιν δτετεμψιιν δν πϊηιν ωμψεα ϊξφΰ ΰεϊν ααιωεμ αϊπεψ ΰε αϊαωιμι χγιψδ (μΰ ρθιιχιν μξπβμ) φεεΰψ, λϊσ, τιμδ ξγεξδ, ειραψθΰο, ηζδ, τμΰγδ, ΰεζιϊ, φ'ΰχ λξςθ δλμ δεμκ, ξδ ωδετκ πιϊηι αωψ ζεμιν ιηριϊ μξςγο χεμιπψι ξψεξν πτω.
    Can leftover be reheated?
    δΰν ΰτωψ μηξν ΰϊ δωΰψιεϊ?
    Absolutely,
    however they are to be reheated in the oven, not a microwave, that ruins the texture and turns the meat chewy
    ααγΰι, ΰαμ ψχ αϊπεψ, δξιχψε δεψρ ΰϊ δξιψχν εδετκ ΰϊ δαωψ δξςεωο μξρθιχ.
    How long can smoked meat last refrigirated?
    λξδ ζξο ιωξψ δαωψ δξςεωο αχιψεψ?
    Very long time, the smoking prosccess cure the meat and prevents spoilage....a 1000 year old technology.
    δψαδ, δςιωεο δεψβ ΰϊ δαχθψιεϊ ααωψ εξεπς χιμχεμ, ελμ ζδ ξθλπεμεβιδ αϊ ΰμσ ωπιν.
ID:	4529   Click image for larger version.
ID:	4530   Click image for larger version.
ID:	4531   Click image for larger version.
    ηαψ ψωεν Bulldog's Avatar
    Denton Tx
    ζδ αργψ, ςεξψ ιχη ΰϊ δϊεγδ ωμε ξηψ ξηεξξϊ αϊπεψ, ςν δωΰψιεϊ ωμ δαιψδ ωδεΰ δαιΰ διεν.
    ηεψπι, ηεψπι, ΰαμ ιεγς ςμ ΰιζδ φγ ωμ δξαψβ γετχιν ςν δτθιω.
    διεν ωμι λαψ ςαψ.
    Don't make me break my foot in your ass
  1. αψβι ξπιτδ
    ςμ ιγι boaziko ατεψεν τεψεν ρεζεχι Suzuki
    ϊβεαεϊ: 2
    ςγλεο ΰηψεο: 11-04-06, 21:47
  2. αψβι βωψ δβιψ
    ςμ ιγι yogibear ατεψεν τεψεν β'ιτ ριχρ CJ
    ϊβεαεϊ: 16
    ςγλεο ΰηψεο: 17-12-05, 21:52
  3. αψβι ΰμο μμεχψιν
    ςμ ιγι itay-rover ατεψεν ΰεσ-θετιχ
    ϊβεαεϊ: 10
    ςγλεο ΰηψεο: 11-04-05, 21:17
  4. ηιζεχ αψβι ψΰω - ξεξπθιν
    ςμ ιγι ρεζι δξωϊεμμϊ ατεψεν ΰεσ-θετιχ
    ϊβεαεϊ: 2
    ςγλεο ΰηψεο: 12-09-03, 11:00
