оцйв ъецаеъ 1 тг 6 оъек 6
    бшйшъ озгм щоп орет мгйжм бзйшд бйп API CF м CI
    ацмй борет - ишефш гйжм - дгшйщъ дойрйоен мщоп дйа мъчп API CD.
    арй ощъощ б- API CF .
    бод йъшен отбш м-CI ае CJ , дан оецгчъ ддщчт ? - дшй деа ъелрп м-CD
    бшйшъ озгм зежш: щоп орет мгйжм бзйшд бйп API CF м CI
    мгтъй аъд цшйк CF4, ема CF. ъбгеч щеб (йщ дбгмйн). аъд йлем мтмеъ байлеъ- жд шч иеб.
    асу.
    айп ълрйъ. зййн. рчегд.
    ISUZU гешщъ CD
    йщ огбчд тн дъчп тм догйг вебт щоп еогбчд бзжйъ ъа дорет.
    оайфа дгшйщд м CF4 ?
    емщамд дочешйъ, орет щъелрп м CD йфйч ъетмъ мощм о-CI ? бод ? ае жд отох лсфй ойеъш ?
    д4 бгшк лмм гшещ моретйн тн иешбе.
    орет шч йшеейз оCI. ллм щдъчрйн згщйн йеъш, лк дщзйчд щм доретйн чирд йеъш. жд, бвгем, дтчшеп.
    асу.
    ъегд асу
    масу емоътрйрйн,
    арй ощъощ тг дйен бщоп орет - valvoline synpower сйриий ома тн API CF
    ебшез од щрлъб лап шцйъй мтбеш м API CI-4 PLUS . ддомцд овеу дъойлд дилрйъ VALVOLINE дйа мдщтш б CF :
    The SynPower 5w40 is still the highly recommended and best oil for the TDI diesels, as the Premium Blue is more for the Heavy Duty diesel applicaitons. You are using the best oil right now for that application.
    The Premium Blue Extreme 5w40 does work for the API CF rating, but a lot of times for the TDI Diesels, you will have to meet manufacture specifications instead of just the API. The SynPower will meet those manufacture specs.
    CF is for passenger cars, vans, pick-ups.
    CF-4, CG-4, CH-4, CI-4, are specifications for trucks.
    Premium Blue is meant for trucks.
    Such oils are filled up with additives which may pollute
    the combustion chamber of your engine.
    SynPower 5W-40 is tested according to ACEA standards and so
    the quality of the oil is much higher than the API standards (CF) etc.
    SynPower quality is high enough to handle the extra dirt coming
    from the EGR system.
    The circle date on the bottom of the can is the date when the plastic
    bottle was made. it is not the filling date of the oil.
    If oil is on a shelf in a dry warehouse in a closed bottle it will last 10
    years.
    But after 10 years you have an antique oil because the OEM specs go on and
    on.
  1. дан афщшй мдзмйу мFJ орет мгйжм?
    тм йгй gilinash бфешен фешен иейид Toyota
    тглеп азшеп: 18-05-11, 22:16
  2. щгшев орет обржйп мгйжм
    тм йгй айфеп бфешен фешен шлб щиз 4X4 лммй
    ъвебеъ: 9
    тглеп азшеп: 17-09-07, 12:24
  3. дзмфъ орет огйжм мбржйп
    тм йгй рцшъй бфешен фешен в'йф сефд ешрвмш YJ/TJ
    тглеп азшеп: 14-04-07, 17:44
  4. дзмфъ орет сефд мгйжм
    тм йгй оерй аешбк бфешен фешен шлб щиз 4X4 лммй
    ъвебеъ: 8
    тглеп азшеп: 28-12-05, 10:10
  5. дзмфъ орет мгйжм бшййрв'
    тм йгй lironc бфешен фешен мргшебш Land Rover
    тглеп азшеп: 25-06-04, 01:09
