ξφιβ ϊεφΰεϊ 1 ςγ 3 ξϊεκ 3
    ηαψ ψωεν sapog's Avatar
    Sep 2009
    ψΰωεο μφιεο
    αψιψϊ ξηγμ ξιγεϊ WMS to WMS ωμ ρψπι γπδ ε-AMC δχιιξιν αΰψυ
    ωμεν ηαψιν,
    ξιωδε ξλν ιεγς μρτχ θαμϊ ξιγεϊ WMS to WMS ωμ ρψπι γπδ ε-AMC δχιιξιν αΰψυ?
    ϊεγδ,
    θμ.
    ηαψ ψωεν cj 64's Avatar
    Apr 2009
    αβεω γο
    αψιψϊ ξηγμ ϊβεαδ μδεγςδ: ξιγεϊ WMS to WMS ωμ ρψπι γπδ ε-AMC δχιιξιν αΰψυ
    φιθεθ πλϊα αξχεψ ςμ ιγι sapog φτιδ αδεγςδ
    ωμεν ηαψιν,
    ϊεγδ,
    θμ.
    ΰν ϊελμ ϊϊψβν ΰϊ ζδ μςαψιϊ.
    εΰπι ΰϊο μκ ϊωεαδ ααχψ.
    γξεχψΰθιιδ?δξφΰδ ωμ πωιν!!
    ξπδμ GodsFather's Avatar
    ξξω ξςαψ μτιπδ
    αψιψϊ ξηγμ ϊβεαδ μδεγςδ: ξιγεϊ WMS to WMS ωμ ρψπι γπδ ε-AMC δχιιξιν αΰψυ (εςεγ λξδ ρεβιν)
    βμ (εΰηψιν) -
    WMS=wheel mounting surface. the flat area around the wheel studs.
    ψεηα ρψο
    ϊψΰδ ΰϊ ζδ -
    AXLE WIDTHS
    ------JEEP------
    '41 to 45 Jeep MB: 48.25"
    '46 up CJ-2A, CJ-3A : 48.25"
    '49-65 Jeep Utility Wagon: 57"
    '49 Willys Jeepster 2WD 57"
    '52 up CJ-3B: 48.44"
    '52 M-38A 49.19" (Military width)
    '54-71 CJ-5 48.44" (so called early-
    '55-75 CJ-6 48.44" narrow axle)
    '47-65 Pickup (the classic) frnt-56" rr-63.5"
    '63-69 J-200, J-2000 65.5"
    '63-69 J-300, J-3800 65.75"
    '70- 72, Gladiator J-2000 frnt-63.5" rr-63.81"
    '70- 72, Gladiator J-4000 frnt-63.8" rr-64.38"
    '73 J-2500 frnt-63.5" rr-63.8"
    '73 all other J trucks frnt-63.9" rr-64.4"
    '74-75 J-10 frnt-62.9" rr-63.8"
    '76-87 J-10 frnt-63.3" rr-63.8"
    '74-75 J-20 frnt-62.9" rr-64.4"
    with disc brakes: frnt-63.0" rr-64.4"
    '76-84 J-20 frnt-64.9" rr-65.9"
    '63-72 Wagoneer 57"
    '73 Wagoneer frnt-57.3" rr-57.5"
    '74-75 Wagoneer frnt-59" rr-57.5"
    '74-75 Cherokee (full size) frnt-58.8' rr-57.5"
    '76-91 Wagoneer, '80+ Cher frnt-59.4" rr-57.8"
    '76-79 Cherokee (full size) frnt-59.2" rr-57.8"
    '76-78 Cherokee S frnt-59.5" rr-58.5"
    '76-80 Cherokee Chief 2 dr. frnt-65.4" rr-62.3"
    '81-83 Cherokee Chief 2 dr. frnt-65.3" rr-62.3"
    '67-71 Jeepster C-101 50"
    '72-73 Commando C-104 frnt-51.5" rr-50"
    '72-83 CJ-5, frnt-51.5" rr-50" (so called-
    '76-81CJ-7(some '81CJ8's) frnt-51.5" rr-50" narrow axle)
    '82-86 CJ-7 frnt-55.8" rr-55" (so called- wide axle )
    '81-85 Scrambler, CJ-8 frnt-55.8" rr-55"
    '84-87, 93 up Cherokee XJ ?"
    '88-92 Cherokee XJ 60 5/8"
    '86-92 Comanche, 60 5/8"
    '87 up Wrangler, YJ 58"
    '93 up Grand Cherokee, ZJ 58"
    TJ Rubicon 03 (F) Dana 44 61" (R) Dana 44 60"
    ------FORD-------
    Bronco 77 (F) D44 58"
    Bronco 77 (R) Ford 9" 57"
    F250 78-79 (F) D60 69.25" (driver drop, king pin, leaf spring sprung: 31.5")
    F350 78-79 (F) D60 69.25" (driver drop, king pin, leaf spring sprung: 31.5")
    F350 '85-'91.5 (F) D60 69.25" (driver drop, king pin, leaf spring sprung: 36.5")
    F350 '92-'99 (F) D60 69.25" (driver drop, balljoint, spring sprung: 36.5")
    1/2 Ton '70 (F) D44 65" (high pinion)
    1/2 Ton '70 (R) D60 65"
    Bronco 77 (F) Dana 44 58"
    F250 78-79 (F) Dana 60 69.25" (driver side drop, king pin, leaf spring span: 31.5")
    F350 78-79 (F) Dana 60 69.25" (driver side drop, king pin, leaf spring span: 31.5")
    F350 '85-'91.5 (F) Dana 60 69.25" (driver side drop, king pin, leaf spring span: 36.5")
    F350 '92-'99 (F) Dana 60 69.25" (driver side drop, balljoint, spring span: 36.5")
    1/2 Ton '70 (F) Dana 44 65" (high pinion)
    1/2 Ton '70 (R) Dana 60 65"
    ----TOYOTA-----
    '79-85 front axle~ 55.5", rear axle~ 55"
    '86-95 front IFS~ 59", rear axle~ 58.5"
    Tacoma & '96-up 4runner front IFS~ ? rear axle- 60"
    T100 front IFS~ 65", rear axle~ 66.75"
    Tundra front/rear~ ??
    '90-97 Landcruiser FJ-80/FZJ-80 front axle~ 63.5"
    -----CUSTOM WIDTH D44s USING COMBOS OF STOCK SHAFTS------
    Chevy Dana 44 width possibilities using stock length axle shafts:
    (Axle widths are, WMS-WMS - wheel-mounting-surface to wheel-mounting-surface. Perch widths are center to center)
    69" wide, 31.5" perches- stock Chevy 8-lug
    68.75" wide, 31.5" perches- Chevy axle with Ford 5-lug outers
    67.5" wide, 31.5" spring perch centers- stock Chevy 6-lug
    65" wide, ~29" perches- long side cut down 2-3/8", use 70's Ford long side axle shaft
    64.5" wide, 29" perches- long side cut down 3", use late 70's Wagoneer long side axle shaft
    63.5" wide, 27.5" perches- long side cut down 4", use 80's Wagoneer long side axle shaft
    62" wide, 29" perches- long side cut 4", short side 1.5", use 80's Wagoneer long side, Dodge short side.
    Chevy
    K30 '79-'87 (F) Dana 60 69.5" (pass. side drop, king pin, leaf spring span: 32")
    K30 CC '88-'91 (F) Dana 60 69.5" (pass. side drop, king pin, leaf spring span: 32")
    International
    Scout 80 (R) Dana 44 60"
    Mercedes
    Unimog (F) 404 69" (driver's side drop)
    Unimog (R) 404 69" (centered)
    Unimog (F) U-1300 82"
    Unimog (R) U-1300 82"
    Unimog (F) 411 55.5"
    Unimog (R) 411 55.5"
    Nissan
    Hardbody (D21) 86.5-97 (R) H233B 59"
    Hardbody (D21) 86.5-90 (R) C200 59"
    Frontier (D22) 99-2000 (R) H233B 62.5"
    Isuzu
    Trooper II 87 (R) Corporate 59"
    Rodeo pre-'97 (R) Dana 44 58" (sua)
    Rodeo 97-99 (R) Dana 44 60.5" (4-link)
    Rodeo 00-03 (R) Dana 44 63" (4-link)
    KIA
    2000 Sportage (R) 60"
    πμχη ξτδ -
    http://www.bentframe4x4.proboards.co...32&page=1#4338
    ςλωιε ψχ φψικ μψΰεϊ ξδ ξΰμδ χιιν αΰψυ ειϊΰιν μτψειχθ ωμκ
  1. ξιγεϊ φξιβιν ξΰεωψεϊ - ΰτωψ ωϊι ξιγεϊ?
    ςμ ιγι landY ατεψεν τεψεν ψλα ωθη 4X4 λμμι
    ϊβεαεϊ: 9
    ςγλεο ΰηψεο: 11-08-09, 23:29
  2. φξιβι 205/75/15 ωθη ξμΰ χιιξιν ?
    ςμ ιγι ρεζι δξωϊεμμϊ ατεψεν τεψεν ρεζεχι Suzuki
    ϊβεαεϊ: 35
    ςγλεο ΰηψεο: 29-02-08, 13:58
  3. CJ7 - ξΰιζε ωπδ χιιξιν αΰψυ?
    ςμ ιγι asafk ατεψεν τεψεν β'ιτ ριχρ CJ
    ϊβεαεϊ: 3
    ςγλεο ΰηψεο: 09-01-06, 21:51
