    asafk's Avatar
    http://www.jeepolog.com/jp_forum/viewtopic.php?t=8074
    http://www.jeepolog.com/jp_forum/viewtopic.php?t=5520
    BOLT ON, , ?
    ? 65? 75? 100? ? ( 100W , . 100... ? )
    - VW TYPE 2 1978 | - 2008
    's Avatar
    May 2004
    1,129
    '. " ( ) Datasheet "" " .
    , 90 ....
    Jul 2004
    1,493
    ( ) : 200 "
    BOSCH 75A
    95AB-10300-DB
    0123310029
    700 "
    TDI200
    BOSCH - 600~500
    85AMP
    TDI300 :
    AMR4249
    A127-65amp
    Denso Alternator
    V8 :
    PART # RNE846
    ALTERNATOR - 100 AMP
    V-8
    MAGNETI MARELLI
    $740 -
    TDI200
    's Avatar
    May 2004
    1,129
    , . 90 PK ( Poly V), TDI 200, 70A.
    DENSO -300 TDI !
    Jul 2004
    1,493
    230
    052-3489211
    04-8725990
    7
    : 03-6817357
    - 600
    Gilad's Avatar
    Apr 2004
    1,616
    (TDI 300)
    3 .
    -850 ". ?
    gali's Avatar
    Mar 2004
    961
    's Avatar
    May 2004
    1,129
    - ( , !) - ( ND ) - , .
    gali's Avatar
    Mar 2004
    961
    DELCO REMY AC DELCO ??
    Jul 2005
    1,514
    100AMP " " . TDI 70 AMP ( ? ) 100 AMP
    72 AMP 100 AMP .
    's Avatar
    May 2004
    1,129
    gp1
    72 AMP 100 AMP .
    . DELCO REMI AC DELCO " , .
    DELCO REMI, HEAVY DUTY , . - .
    - , /"/"/ . A1 ( ") . (!) , ...
    Gilad's Avatar
    Apr 2004
    1,616
    Jul 2005
    1,514
    . . TDI , - 10 " . . ( ) .
    Jul 2005
    1,514
    ELECTRICAL
    System ........................................ ..................................... 12 volt, negative ground
    Battery
    Make/type - standard ........................................ ............... Land Rover Parts and Equipment/Lucas maintenance
    free 9-plate 072
    Make/type - heavy duty ........................................ ............ Land Rover Parts and Equipment/Lucas maintenance
    free 14-plate 663
    Generator
    Manufacturer ........................................ ............................ Magnetti Marelli
    Type ........................................ ........................................ . A127 - 100amp
    Polarity ........................................ ..................................... Negative ground
    Brush length:
    New ........................................ ................................. 17 mm
    Worn, minimum free protrusion from moulding ........ 5 mm
    Brush spring pressure flush with moulding ...................... 1.3N to 2.7N
    Regulator voltage ........................................ ..................... 13.6 to 14.4 volts
    Nominal output
    Generator speed ........................................ ............. 6000 rev/min
    Control voltage ........................................ ................ 14 volt
    Amp ........................................ ................................. 65 amp
    yoni 110's Avatar
    Jan 2003
    548
  1. -
    tallevi 4X4
    : 9
    : 28-02-25, 21:53
  2. ()
    GodsFather 4X4
    : 0
    : 19-05-09, 14:33
